Results 1 to 2 of 2
Thread: Check engine codes
    Apr 2004
    Default Check engine codes
    Just been reading on BMWe34.net about diagnostics using the check engine light.
    It says to go to bonnevillemotorwerks.com for the engine codes but this site is under construction!
    Can anyone tell me where else I can get the codes?
    Default How bout this?
    1000 End of diagnosis
    1211 Electronic Control Unit (ECU)
    1215 Airflow Sensor
    1221 Oxygen Sensor
    1222 Oxygen Sensor regulation
    1223 Coolant Temperature Sensor
    1224 Air Temperature Sensor
    1231 Battery Voltage out of range
    1232 Idle Switch
    1251 Fuel Injectors (final stage 1)
    1252 Fuel Injectors (final stage 2)
    1261 Fuel Pump Relay
    1262 Idle Speed Controller
    1263 Tank Vent
    1264 Oxygen Sensor heater relay
    1444 No faults in memory
  1. Check Engine codes?
    By elbasha in forum 5 Series BMW
    Last Post: 07-07-2008, 07:24 PM
  2. 91 535iA trouble check engine/codes continue
    By Rigmaster in forum 5 Series BMW
    Last Post: 11-11-2006, 07:05 AM
  3. Can you read check engine codes through OBC?
    By Strap in forum 5 Series BMW
    Last Post: 10-18-2005, 06:58 PM
  4. Trying to get engine codes
    By phildg2000 in forum 5 Series BMW
    Last Post: 07-14-2004, 08:46 AM
