Results 1 to 7 of 7
Thread: Transmission problem - new to BM's
    Aug 2004
    Default Transmission problem - new to BM's
    Hi
    I have just bought my 1st BMW, 1991 E34 520i.
    I think I may have a problem with my auto transmission. My last car a 190e Merc hads a very 'direct' feel when you put the foot down, this car seems to rev more and eventually you feel the speed increase.
    My 1st instinct is to check the transmission fluid level - not sure how to find it!(no owners manual).
    Can any of you offer some advise, and is it possible to download user manuals on the web.
    Whizzo
    Mar 2004
    Austin, TX
    First off, welcome to BMW and the forum. It's true Mercedes' tranny's shift much more harshly than a BMW. However, if your transmission is slipping, that's not the way it's supposed to work. I'd suggest taking the car to a independent BMW tech. I'm pretty sure '91's dont have a dipstick as the transmissions are sealed. If it is low, a good tech should be able to top it off.
    You can get a replacement owners manual from the dealer for around $16. If you plan on doing any maintainance yourself, you should get a Bentley Repair manual. They run $35-40 and will pay for itself the first time you use it. That along with this forum will be invaluable for maintaining your car.
    Wichita KS
    Default I've noticed the same
    Quote Originally Posted by Whizzo
    Hi
    ... this car seems to rev more and eventually you feel the speed increase.
    Whizzo
    Torque converter really lets the engine rev a lot in comparison to other cars I've driven (91 525iA). Worked the same despite fluid service/replacement and transmission replacement. I guess that's the way they're made.
    Last weekend I had the car at drivers' school--just had to see how it would all work. I finally got to the point where I would floor the accelerator at turn-in. Then the trans would downshift and engine would be wound up at the apex.
    Default Where I come from, "BM" has a different meaning.
    I.e., Bowel Movement. I hope this isn't your first! If so, I'm sure you will like them - but be careful, they're habit forming.
    Robin
    72 Chevy K10
    01 E39 M5
    Texas
    Being that the trans that was put into the car from the factory had a dip stick...and the replacement trans does not.....the fill hole, that is the left hand side bolt, driver's side for US cars, correct? Once filled, the fluid should be at the botton edge of the hole....? (where is the DME relay BTW?)
    Thanks.
    Aug 2004
    Thanks for the replies - Brian S - what is a DME relay?
    Texas
    it is the Digital Motor Electronics. DME/Motronic Systems Relay. The Control Unit is the main computer...from what BMW explained. The relay is more or less a fuse. I am hopeful that my Trans Program Message is due to the relay being bad.....for $25.20 at John Roberts BMW, it's worth a shot. If not, then I will check into bulletin # 62 05 94 (14131)....check the voltage of the RxD line (pin 25 of the connector X8500). If this voltage is not above approx 10 volts, the Trans Control Module will not ground pin 29 of X8500, causing the Check Control Module to post a "Trans Program" warning. Low voltage on teh RxD line can be caused by an intermittent short to ground on the RxD line....example, at X275 under t he driver's seat....if teh ground is detected...it can be repaired with electrical tape...
  1. Transmission problem, BMW says no warranty!
    By scott 4991 in forum 3 Series BMW
    Last Post: 01-17-2007, 11:52 PM
  2. Transmission problem, BMW says no warranty!
    By scott 4991 in forum 5 Series BMW
    Last Post: 01-12-2007, 05:17 PM
  3. Weird Transmission Problem
    By kngpen in forum 5 Series BMW
    Last Post: 11-12-2004, 07:24 PM
  4. Transmission/New Clutch problem. Help!
    Last Post: 05-06-2004, 10:51 PM
  5. Automatic Transmission problem
    By rob520i in forum 5 Series BMW
    Last Post: 04-15-2004, 03:34 AM
