offset of 13mm front and 25mm rear will they fit the 89 525i without mods.
I have some rims that i would like to get for my 89 525i 5spd, and i just wanted to see if they would fit without any mods.
This is a normal E34 rim:
Hub center diametre: 72.5 mm
Number of bolts: 5
Pattern: 120 mm
Offset (ET): 20mm
And this is the rims i want to get with tires:
Hub center diametre: 72.6 mm (will this effect anything, 0.1mm difference)
Number of bolts: 5
Pattern: 120 mm
Offset (ET): Front wheel-18/8-(ET)13mm
Rear wheel-18/9.5-(ET)25mm
And the tire (Flaken) size are 235/40/ZR18 front and rear is 265/35/ZR18
They say that it comes with bmw specification correct / m badge indentation / hub centric (<-- are there the hubcentric rings.)
original center caps and m badges included
Plus here is a link
http://cgi.ebay.com/ebaymotors/ws/eB...category=66484
Any help would be great, Thanks.
"No matter how it looks its still my ride."
They should work but I think you may have rubbing in the rear with 265s. Should fit fine though with hubcentric rings.
Custom Turbocharged 1991 535iM - 135k mi.
