1989 735il
How many gallon gas tank?
21 i think
Also how high to fill power stearing resevoir.....no dipstick and car didn't come with manual....also if I run it to low will I have problems having to bleed rear suspension?
if the car has vacuum brake boost fill to about 1" from top, if the car has hydro boosted brakes with the engine off stomp the brake pedel about 20 times or till you can't get the fluid to rise anymore, then fill till it's just above the bottom of the screen, if over filled the brakes can lock during extended use and the car won't want to move (sort of drag in traffic)
