Results 1 to 5 of 5
Thread: Evaporator ??
    Mar 2004
    Default Evaporator ??
    I thought it was my heater core that went out, but after some disassembly, it looks like the evaporator. All the coolant leaked through the drain out onto the exhaust, which smoked like a mother........ Has this ever happened to anyone else?
    Thanks, and BTW, the trunk is STILL jammed.
    Mike S.
    1992 535iM black/black
    1997 540iM white/gray
    Retired: 89 535iA, 85 318i
    <<Support your local autobahn, stay out of the left lane!>>
    baton rouge, loserana
    the valve usually leaks enough for the oil to turn the right side rubber drain into jello, but they generally don't puke hard
    Quote Originally Posted by mikemaster
    Mar 2004
    Thanks Winfred.
    Follow-up question:
    Is it really necesary to replace the drier after I change the evaporator and expansion valve? While searching, I've seen some say that you have to replace it every time you open up the system. Any thoughts?
    Mike S.
    It is recommended... but lots of people I know don't. Especially when your vacuum the system before refilling it.
    when changing a major component i strongly recomend a new drier, but not when the system is only open a few minutes to change a o-ring
    Thanks Winfred.
    Follow-up question:
  1. How to remove evaporator in RHD car
    By myles in forum 5 Series BMW
    Last Post: 12-04-2006, 03:23 PM
  2. Is replacing the A/C evaporator a big job?
    By GAM in forum 5 Series BMW
    Last Post: 11-04-2005, 02:38 PM
  3. evaporator
    By goulmima in forum 5 Series BMW
    Last Post: 11-29-2004, 10:51 PM
  4. Evaporator
    By Lee in forum 5 Series BMW
    Last Post: 09-06-2004, 01:17 PM
