Results 1 to 10 of 19
Thread: front weels vibrate when braking
    Aug 2004
    Dubai
    Default front weels vibrate when braking
    I have thei 535i E34 90 model I have new Disks and bushings, new arms front and rear. and new weels and new alloys .. but I still get this vibration. anyone knows the problem?
    Jul 2004
    Holly Springs,North Carolina
    Quote Originally Posted by grave77
    Check the rear arms and your swaybar links. I had the same problem and got new control arms and new swaybar links. So far so good.
    Perth, Australia
    I had pretty bad vibration under braking in my car. Got the front shocks replaced (one of them was completely dead), bump stops and idler arm bushings. It's almost gone now, but there's still a slight vibration under initial braking, but not enough to bother me.
    Melbourne, Australia
    Even though you have new discs make sure there is no runout, which can occur if there is dirt or grit caught between the mounting faces etc. My experience with BMW brakes is that they are really sensitive to disc runout and variations in thickness of the discs.
    Aug 2004
    Dubai
    I dont know ... but all what you guys said was checked disks and brake linings, arms front and rear were changed too. I'm doubting the shock absorbers but they are stiff.
    Perth, Australia
    forget my post about the shocks and idler arm, it lowered the brake-shakes a fair bit at first, but now it's back and worse than ever... next on my list will be sway bar links and control arms... I get a clunk when i hit a bump with my right front wheel, so I can rule out warped rotors (at least, that's not the only problem! sigh..)
    Apr 2004
    Raleigh, North Carolina
    I have a serious shimmy in braking when descending through 60-50 area, as well as a misalignment when cruising at about the same speeds. From what I've read so far in this thread (and in archives), I can narrow it down to the following:
    ALMOST EVERYTHING IN THE FRONT SUSPENSION
    That might be a little pricy, by way of replacement parts AND time. It looks like the upper control arm bushings are dry and worn out, and there's a lot of space between the through-bolt and the bushing on both sides. Is that normal? Should the bushing fit snugly around the bolt?
    Could I just replace the bushing, or do I need an entire new control arm? Or, is it probably something else altogether?
    TIA -
    Ex-Calypso Red 540i owner
    Default get the complete thrust arms
    with the 740 bushings already installed. I dont think there should be any play (of significance) between the bolt and collar but once torqued down that play should tighten up.
    Apr 2004
    Here's what I mean, Jeff:
    Tampa Bay, Florida, USA
    Pick up the entire arm from BMA with the 750 bushings already installed.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
  1. Replies: 6
    Last Post: 10-11-2009, 09:28 AM
  2. Replies: 4
    Last Post: 09-02-2008, 03:58 PM
  3. front end shake when braking ....
    By fsteyer in forum 5 Series BMW
    Last Post: 06-04-2007, 05:49 AM
  4. front end grind noise on hard braking
    By pba in forum 5 Series BMW
    Last Post: 09-04-2006, 05:25 AM
  5. Car braking by itself!
    By romus in forum 5 Series BMW
    Last Post: 10-16-2005, 12:30 AM
