Results 1 to 4 of 4
Thread: Turn Signal Bulb problem
    Default HID Bulb repair 101
    Recently the metal at the top of one of my HIDS has disconnected from the tip in the middle. I can re hook it to the middle, but it just bounces lose causing the bulb to not work. I dont want to pay for a new set of bulbs as they are very expensive. Do you think it would work to solder the tips of the two middle pieces together, they are both at the top of the bulb as seen in this picture
    95 BMW 525i black/black
    -E.A.T. chip
    -Blacked out grill and window trim
    -17in AC replicas
    -Blistein shocks & H&R springs
    -Cadmium plated Brembo rotors
    -Raybestos QS break pads
    TC535i Guest
    You put the wrong bulb in there. There should be an 1157 (dual filament) in the corner, you replaced it with a 1156 (single filament).
    Quote Originally Posted by TC535i
    Should I get this from the bmw dealer, or autozone?
    -E.A.T. chip
    -17in AC replicas
    awwww, just noticed in the old bulb! There are two filaments, and one of them is burned out. That is why it only works halfway, hahahha tricky.
    -E.A.T. chip
    -17in AC replicas
  1. Fixed turn signal/highbeam problem
    By gale in forum 5 Series BMW
    Last Post: 11-18-2007, 07:25 PM
  2. Head light/Turn signal problem
    By Milkboot in forum 5 Series BMW
    Last Post: 12-11-2006, 02:45 AM
  3. Turn Signal problem
    By bimmerlee in forum 5 Series BMW
    Last Post: 05-15-2006, 04:25 AM
  4. turn signal bulb question
    By GoldenOne in forum 5 Series BMW
    Last Post: 04-22-2006, 02:28 PM
  5. Turn signal and Flasher Problem
    By SU1973 in forum 5 Series BMW
    Last Post: 11-21-2004, 08:24 PM
