Must be fited properly
Remove (pry out) the old triangular shaped inserts (mine were blue). There are only two. Then fit the new inserts on each side of the bushing. There are four red inserts. Take care to fit them properly around the triangular shaped portion of the bushing. There appears to be only one way they can fit.
As far as I know,I am the only person who had squeaks after installation. I sprayed "super lub, a synthetic lube" on the bushings and no more squeaks.
Originally Posted by
525SEI BRIT
Hi all, hopping somebody can help me out with Bruno’s Delrin inserts! All the information I’ve found so far is kinda brief! I am fairly mechanically competent but I have a few questions. I finally got round to getting under the car this weekend to check them out and found that on my 525 there is a gap between the inside of the outer subframe (trailing arm) mount and its bracket but not on the outside of this mount.
Am I to assume the inserts are to be placed in-between the outer trailing arm mount and the bracket on the chasse in order to fill this gap?
Also mine sine to have tapered inside edge i.e. the inside hole is bigger on one side than the other! (55mm diameter one side 52mm the other!) Dose it make a deference witch way round they go?
Could this be why some people have experienced squeaking?
