where can i buy a 3.91 lsd?
find it in most inner city cross streets, may go under other names as I havent "experimented" in a bit.
you might need to keep a lookout on Ebay if you dont mind used. new IS nice but a bit pricey to me.
your 535 uses the pin ass sized differential jusy like mine. the 540 is much beefier. the one we need is so small and pin it wouldnt last one race day at a quartermile track, made for smooth power no impact design.
so i got a reply back and sure enough just as Jeff predicted its pricey as all hell.
Hi Martin,
A 3.91 LSD for this car is $1950 plus core and shipping.
Core charge is $750
Brett Anderson
KMS
so can i drop a 540i diff into mine?
Give me a couple of days- I know where some E34/E32 LSD's are hiding- just need to confirm what ratios are available. I believe that Koala's price is for a "rebuilt" unit, probably with increase lockup %..... Still hard to justify the price IMHO......
Bret.
You will have to change out more than the differential, change the input flange and the driveshaft output, the axle shafts, half shafts most likly, housing braketry and I would doubt that would just bolt up either.Originally Posted by bahnstormer
Let Rigman find you one and just bolt it in.
tx rigman!
i'll be waiting...are u parts guy? or do u just know some people that know some other
people =] ?
A little bit of both. I've got a couple E34 parts cars- but I found some BMW diffs at a local yard recently- the guy told me I could take an inventory of the diffs he had on the shelf sometime. I'm gonna try to get back by there this week.
Bret.
forever in your debt sir.
-martin
