You need to replace the oil filter canister. There is a check valve that goes bad. The bad valve allows the oil to return to the sump requiring the engine to re-prime the motor after extended stops. The best place to get one is from a salvage yard. Clean the canister and put it on. It's a DIY job. OEM price for this part is quite expensive.
