Results 1 to 10 of 11
Thread: Alpine In dash Monitor will it fit an E34?
    Sep 2004
    Hertfordshire
    Default Alpine In dash Monitor will it fit an E34?
    Hi all,
    Does anyone have any experience of fitting an Alpine in Dash monitor in an E34 right hand drive car?
    It is a standard DIN size unit but when you turn the ignition on it has a fold out screen that comes out and sits at ninety degrees to the dash.
    My only concern is that it will foul on the console where the foglight switches are mounted?
    All the best
    Ben.
    PA
    Quote Originally Posted by ben wilamowski
    Hi all,
    All the best
    Ben.
    yes it fits
    Sep 2004
    Hertfordshire
    Thanks Jon,
    That looks awesome!
    Do you need to tilt the screen at all to prevent it hitting the the dash / foglight switch or does it just come straight out and sit at 90 degrees without a problem?
    What's going through my head is will it try and motor into the dash until I hit the tilt button to make it come forward or can you set it to come out at any angle by default?
    Sorry for all the questions but I just want to know the deal before I spend the cash!
    Cheers
    Ben.
    PA
    Thanks Jon,
    That looks awesome!
    Cheers
    Ben.
    The alpine units will fit perfectly fine tilted back past 90 degrees... meaning pointing up kind of at you. You can use the full range of tilt without hitting the foglight switch IF you do what i said and use the SLIDE feature. The slide feature is a feature that is for cars like ours where it needs a little clearance. So hold the OPEN/CLOSE button, the unit will slide forward by about 3/4" or so and then it has full range of tilt. here is a picture at a side angle so you can see...
    Mar 2004
    Phoenix, AZ
    Default What? How Much? Where?
    Both of the posted picts. look great. What is the alpine model number for this unit? How much is it? Is it also a stereo receiver that can also play CD's?
    I've wanted one of these ever since the first pict. was posted on this site.
    Need the info., the 411, the scoop! Lay it on me.
    JD
    Sep 2004
    Hertfordshire
    Dear Jon,
    Thank a lot for that mate,
    Will go for it now!
    Ben.
    PA
    Quote Originally Posted by JD525IA
    JD
    Alpine CVA-1004 Multimedia Unit. ($1000 retail)
    No CD player, requires CD changer. LCDII technology, blah blah. One pre out expandable to 3 with KVE-104 exansion module ($500 retail).
    Wow... what's that second screen? You better anchor that head unit in to prevent thief from yanking it out easily.
    PA
    Quote Originally Posted by Tiger
    Second screen is 7" touch screen LCD running from my CarPC, navigation, MP3, Video, Internet... etc.
    The lower screen retracts.
    Connecticut
    Jon K,
    I am in the process of getting parts to install a CarPC in my car and was wondering which touch screen you went with. Also how has glare been with the screen mounted there? Because that is the same spot I was going to mount mine, but I am worried about glare and not being able to see the screen.
    TIA,
    Phil V
  1. Alpine box
    Last Post: 12-24-2008, 02:20 PM
  2. (exhaust, gas, oxygen) monitor
    Last Post: 12-08-2005, 04:42 PM
  3. In dash monitor
    By casurfer911 in forum 5 Series BMW
    Last Post: 10-29-2004, 09:33 AM
