Results 1 to 10 of 11
Thread: Before/After springs,shocks,sways.. 93 525ia 159k sharked
    Aug 2004
    RTP North Carolina
    Default Before/After springs,shocks,sways.. 93 525ia 159k sharked
    Ok I'd first have to say thanks to 632 Regal for all the help, and the new used lowering springs.
    Now to the upgrades
    Bavarian Auto springs all around.
    New Boge Turbo Gas on all corners
    New M-tech sways 25mm front 19mm rear.
    Replaced the fog lights and a couple cracked Headlight lenses.
    On backorder awaiting to install
    ::: Bavarian Autosport Clear Urethane Headlight, Parking Light and Foglight Shields. If these save one light they will pay for themselves.
    First impressions after a day's riding. Weeee!.. Car handles like on rails!! With each new upgrade brings shortfalls.. Now the tires need to be replaced. I can feel the tire flex in the corners now. Next spring I'll take care of that.
    you like?
    Aug 2004
    RTP North Carolina
    So very much so
    I knew you would, I like the way the front sits, much higher than mine did with them. perfect for the 6 cylinders!
    Olympia, Wa
    Quote Originally Posted by smcgowan
    Now to the upgrades
    smcgowan, Looks good. How does the ride feel. I am thinking of doing the same thing but have not decided on what springs and shocks to use. Approx how much did it lower in the front and rear?
    Phx AZ
    I'm surprised your front is that high. I have the same setup and my front dropped to the tire. There is no fender gap at all, in fact it probably overlaps the tire a little. Perhaps yours hasn't completely settled.
    Aug 2004
    RTP North Carolina
    It's does look like it is starting to settle a little the car hasn't even been driven 50 miles since the new shocks and springs. The M5 sways make the car very flat in the corners. As i stated I can feel to the tires flex now. The overall feel on the ride as greatly improved and not to stiff of a ride. I didn't go any stiffer springs or stocks, because I want to keep the ride close to stock. Wife wouldn't like to feel every bump in the rode.
    I forgot to thanks Bruno for all his great work on his website.. LOve it and for the Sway bar numbers.
    AND BMA for the parts.
    Next upgrade new tire and bigger brakes..
    Phx AZ
    How much did the sway bars run?
    Aug 2004
    RTP North Carolina
    Default total M-tech sway... Thanks Bruno:)
    2 x 31 35 1 131 622 Frt support bracket
    2 x 31 35 1 134 582 Frt Link
    2 x 31 35 2 226 334 Rubber mount
    1 x 31 35 2 227 276 Frt Stabilizer bar
    2 x 31 35 1 124 995 Rear support bracket
    2 x 33 55 1 135 307 Rear link
    2 x 33 55 2 227 240 Rubber mount
    1 x 33 55 2 227 416 Rear Stabilizer bar
    Total was about 420 including shipping
    Default do you have comparison pics of the sway bars?
  1. Replies: 2
    Last Post: 01-16-2011, 08:03 AM
  2. Used M5 Frt/RR Shocks and Springs
    By TheDuke in forum 5 Series BMW
    Last Post: 12-02-2005, 12:51 PM
  3. Will springs from a 540I fit and 93 525ia
    By smcgowan in forum 5 Series BMW
    Last Post: 09-10-2004, 01:11 PM
