Originally Posted by
jj7
dear all, i am proud to be a part of this forum, and this is my first
posting.
my name is jafar,currently living in malaysia, i imported a 525i 94 from japan, its my second BMW,the first i had was a 520i 91.
the 525i got a long history,but won`t depress with that,at the moment there is the pinging for a year now,lately the car is acting really strange:
1- pinging with gear up-shifting, rpm below 3k
2- hesitation on take off
3- sometimes no response/slow response when gas applied
4- idle most of the time low
more to that,on the modic3 no fault codes,all sensors are within the specs, had the ecu repaired in the US,new catalytic, replaced 2 ignition wires which used to give less than 12v with ignition switch on,cleaned all the ground points as possible, battery flow is optimum,fuel regulator 3bar,new fuel filter, new ignition coils and sparks.cleaned the throttle body.
the car is great and a real bmw when warming up,once the gauge in the middle all those symptoms show up.the only ideas i have is to have the chambers checked for carbon build up and injectors tested and cleaned.
the car is auto...
thanks all
