To split the drive shaft if i recall....
It's tedious but you basically use a box wrench to undo that bolt. You'll need some one to hold the bloody thing while you undo it a 1/4 turn or less at a time. And, for added pleasure, it's a pretty long bolt.
But, it does come undone and then you can split the driveshaft in half.
The next pleasurable part of the job will be removing the old center bearing. Helps to have a gear puller or similar. Be careful when you install the new one to get it one straight and not to tweek the frame when you install it.
Remind me one day to post the story about the adventure we had when we replaced the aft CV joint on the driveshaft. That's another "Martin Bacon, Genius" story.
Have fun.
Jeff
Originally Posted by
Jon K
i identified the part that has the play...
it's #3 in that image... the ball jount end... its the piece that goes in hole #8... there is play in that little shaft that is facing downward...
so question is, do i need to replace the whole tie-rod? or can i just replace that threaded piece? please let me know. its the passenger side one that i am looking for.
Bellevue WA
86 Porsche 951 - Track Toy
