Alan,Originally Posted by Alan_525i
I too had a bad coolant loss this summer and i wasn't sure where it was coming from and i feared the worst... consumption, but as you know (or i think you do) it turned out that my water pump was leaking. apparently the O-ring around the water pump may have seen too many heatcycles because it no longer took up the space between the water pump and block, thus allowing coolant to squeeze past. this could be your problem, and is relatively cheap. about the radiator cap, if you had a coolant leak, it would be very very obvious because of the stain that the coolat leaves. i don't think the system needs to "fill up" so much, and if it did i don't think it would empty the entire expansion tank... but i guess time will tell.
