Diff bearing preload on 540i LSD
Ok,
I've read the section on Bruno's site regarding the diff swap (great write-up). I'm swapping out my 2.93 open diff for a 3.15 LSD out of an '88 750iL. I know I need to install the input flange off of my open diff on the LSD. Question is, how do you properly set the input bearing preload? I've read that you can make match marks on the nut and the 750 flange, back off the nut, then torque it until the match marks line up, measuring the torque as you do this. Then, install the 540 flange and torque to the same setting. Is this the correct procedure? I asked the dealer if they could do this and how much it would cost. The shop foreman (a really decent guy, actually) is out today but will call me tomorrow with an estimate. I wanna do it right, but if I can do it myself and be confident it's done right, I will. Any thoughts or suggestions?
Brian Harston
Waterford,MI
1995 540i/6
