Results 1 to 4 of 4
Thread: Oil Level sensor
    Pittsburgh
    Default Oil Level sensor
    I get an "Oil Level Low" message everytime I start or shut off the car. Even after an oil change and a fresh 8 quarts.
    Is the Oil Level Sensor and the Oil Pressure Sensor the same gizmo? If not, where is the Oil Level Sensor?
    TIA,
    Patrick
    Communist-wealth of Massachusetts
    Quote Originally Posted by PatrickPGH
    TIA,
    Patrick
    Hi Patrick,
    Look at the bottom of the oil pan and you will see a roundish cover on it, that is the sensor. In the M50 it screws out, but all the oil will come with it so probably want to wait until your next oil change. It is a two stage sensor, one part measures the level in the pan and the other is dynamic measuring when the engine is running. Not a super expensive part if it is bad.
    Best,
    Rory
    <Insert list of modifcations or clever saying here>
    Pittsburgh
    Default Same with M60?
    Thanks for the reply Rory. Is the oil level sensor located in the same location on an M60?
    Quote Originally Posted by Rory
    Hi Patrick,
    Best,
    Rory
    Default yep, on the pan, I tapped mine a few times and has been fine
    for abot 15k so far.
  1. oil level sensor
    Last Post: 05-10-2013, 07:13 PM
  2. Q: Oil Level Sensor
    By BMWDriver in forum 5 Series BMW
    Last Post: 08-17-2009, 09:48 PM
  3. coolant level sensor
    By robert g in forum 5 Series BMW
    Last Post: 11-16-2007, 04:30 AM
  4. Oil Level Sensor... argh
    By ElNormo in forum 5 Series BMW
    Last Post: 08-05-2006, 09:01 PM
  5. coolant level sensor
    By riot in forum 5 Series BMW
    Last Post: 12-05-2004, 10:15 PM
