that wheel size is a "standard" e 34 size in that the M5 had those size wheels.235 45 17s or 255 40 17s will retain your speedo readings.Look here to get more info.Take a note of the main URL for that link it has a wealth of info
Will a 17x8 20mm offset fit on a 92 535? If so, what would be the max size tire that I could use?
Thanks-
Chip
'92 535i 5sp
EAT chip, Sachs kit, RRT sport control and upper thrust arms, SS brakelines, Camber plates, Subframe inserts, 3.64 Diff, M5 (3.6L) calipers.
'87 325iS
Gone but not forgotten
5x120 bolt pattern, with a 20mm offset, and hub-centric.
