Results 1 to 10 of 12
Thread: Starter motor won't turn off- can it be fixed or throw away?
    Default Starter motor won't turn off- can it be fixed or throw away?
    The solenoid on the starter appears to not be engaging correctly, so after withdrawing the key, the starter motor is still spinning without engaging. If you give it a (gentle) thump with a non genuine tool (steel bar) it stops and, with some luck everything works the next time starting is attempted. Can the starter motors be easily repaired or is a replacement part easier?
    John 535is Sydney - 1989 (M30) Alpine white, black recaro, HIOP, Bilstien, EAT, 17" BBS.
    I personally would get a replacement starter, never can tell when it will leave you stranded.
    Default Thanks Jeff
    Yep- I intend on getting it fixed, for some reason seeing the hood up on a BMW with the owner hitting something inside the engine bay with a steal pole is amusing to other drivers. Go figure!
    I was just wondering if its something simple or not worth trying to dismantle.
    Sorry to read about the damage to your car.
    John 535is
    Default Looks like rebuilt ones are about $120 US
    I dont know whats available on your side of the pond. Do a little research on who has a better rebuild rating, wouldnt want to do this more than one time.
    Default John, the Bosch starter motor for my 525i...
    is the same unit as used in a Mitsubishi Magna (early model). Much cheaper to buy from Mitsubishi Dealer than BMW Dealer I'm told, but you maybe can get your one repaired.
    Phil
    Default Holey ****! One for my car is almost double!
    baton rouge, loserana
    could be some rust or clutch dust crudding it up, the solonoid is really just a piston in a bore surounded with a coil
    Default Good thought - I'll try some compressed air first
    Thanks Winfred, I'll take it off and try to blow some air through it.
    John
    Default At A$560 from the importer I was hoping for an alternative.
    Quote Originally Posted by Phil Sanderson
    Phil
    Benneton (United Colors of)
    if you have a TIS cd, there are step by step picture instructions for starter rebuilding on it for an e34.....you might just need to lube the solenoid and be OK with it.
  1. R&R 750 M70 starter motor
    Last Post: 04-01-2009, 02:31 AM
  2. Fixed turn signal/highbeam problem
    By gale in forum 5 Series BMW
    Last Post: 11-18-2007, 07:25 PM
  3. E34 540 starter motor
    By Sidney Rough-Diamond in forum 5 Series BMW
    Last Post: 02-12-2007, 05:37 PM
  4. starter out, and fixed!!!
    By kyleN20 in forum 5 Series BMW
    Last Post: 01-25-2006, 06:46 PM
  5. 525 tds starter motor
    By colin jenkins in forum 5 Series BMW
    Last Post: 07-23-2005, 02:43 AM
