Results 1 to 10 of 10
Thread: Lights on air vent??
    Apr 2004
    Chicago
    Default Lights on air vent??
    Are the red and blue temperature indicators on the adjuster wheel in the center dash air vent supposed to light up when the headlights are on??? Also do the white "open" and "closed" indicators alongside the vent light up ??? Mine have never lit up and its a PITA to adjust the temp. and vent in the dark. I think I saw a picture of a lit dash and these were indeed back lit.
    Also, has anyone installed replacement acrylic fog light lenses rather than replacing the complete light???
    netmgr Guest
    Default not on mine
    they dont light up on mine, never did never will...solid plastic with panted legends.
    only ever saw it on e32s the 7 series, and you cant fit that version as its to big.
    perhaps on cars with air con the story may be different...perhaps someone can confirm.
    Mar 2004
    Default I wondered about those lights also. It works on Jon K's Dash.
    http://www.bimmer.info/forum/showthr...hlight=monitor
    Quote Originally Posted by Gordie
    Gordie, I also have a 1995 and mine light up just fine. The little white markers on the sliders are backlit along with the dials for the driver and passenger temps and the fan control. The three buttons controlling A/C, defrost, and internal air circulation only light up when they are pressed. I dont have my Bentley in front of me but I would imagine its an inexpensive fix, but probably a huge pain to actually access the area.
    netmgr Guest
    Default hang on
    hang on before you all start telling him to get it fixed and rip his dash apart - as I say mine is just standard painted dials - perhaps cars with air con have illuminated versions.
    so you need to check - i would have thought it would be self explanatory to tell if yours are painted or rear illuminated
    do you have air con?
    Quote Originally Posted by netmgr
    OK, you are right, dont tear anything apart until you are sure they are supposed to light up. Although, mine look painted on, but they light up at night so it might be harder than it sounds to figure that out. Unless I am just an idiot, which is possible.
    Lexington, Kentucky
    Default thre are no lights on my center vents 95 525i
    Only what appears to painted on red and blue on the center and white on the edges. Did not think they were supposed to light. If they are suppossed to light, I WANT THEM TO LIGHT!
    Quote Originally Posted by CrimsonBrian
    Austin
    The temp adjust wheels light up on either side of the fan control, and the two vents with the hot/cold reostat wheel lights up too.
    To do the temp adjust wheels you need to take out your defrost/recirc/ac button, your radio, and your obc (remember the obc has two clasps, one you can reach with the radio out and the other you need a slim jim to depress it with on the side of the obc and glove box. Then get your hands in the radio slot, and unclip the three vent slider tabs (pic below), and un hook a few wires for the little recirc fan and such, and the temp control will come out.
    If you're gonna change bulbs, change them all. This is the bulb for the temp adjust wheels
    and the procedure for removal
    http://www.bmwe34.net/e34main/mainte...nel_lights.htm (remember that lever you see for the obc is on both sides)
    I believe the vents above the radio will pop out with proper placement of a taped up flat head. There is a write up on that but I don't know where it is.
    Best bet is to take these bulbs with you to the stealer as they are so cheap, and you want to eyeball the replacements.
    Be really carefull unclipping the clips for the slider controls. The one to direct to your feet can break easily. Also putting everything back in and situating the wires are important to get the radio back in, and have it not interfere with the sliders (anyone else have one slider that won't go all the way over or springs back a bit..that's why)
    good luck, and as always, record and host digitals
    Austin
    Found the link, but it's for e32, so FWIW here it is. gotta believe the release clips are in the same place.
    http://www.nmia.com/~dgnrg/page_37.htm
    Nov 2004
    great work and great post...thanks...Don Gale's website is a wealth of knowledge! (even though its an e32)
    Q
    95 525iT / 97 740iL
  1. old vent hose
    Last Post: 10-11-2009, 06:32 PM
  2. weird vent behaviour
    By 525i winter driver in forum 5 Series BMW
    Last Post: 11-16-2008, 05:08 PM
  3. Tail lights, Interior lights, 1 license plate light not working
    By Another Bama Fan in forum 5 Series BMW
    Last Post: 10-28-2006, 05:53 PM
  4. a/c blows cold...top vent and lower vent blow hot?????
    By Anthony 94 525i in forum 5 Series BMW
    Last Post: 05-07-2004, 06:56 AM
  5. Clear corner lights / eBay fog lights quality
    Last Post: 05-05-2004, 08:05 AM
