Results 1 to 10 of 16
Thread: What to do with no stomp test...
    Apr 2004
    New Hampshire
    Default What to do with no stomp test...
    The stomp test doesn't work on my '95 540i (12/94 prod).. Is there any other way short of a code reader to get fault codes?
    Two or three times now I've seen the check engine light pop on while the car is at idle (like at a stop light or something). It goes away as soon as I shift to 1st and start moving again. Any ideas?
    Dennis
    '95 540i 6sp, uuc ssk, Dinan chip
    proud member of the nikasil club
    Default Do a stomp test.
    once you figure it out you will catch on. First time I did it I swore it wasnt an option. sit in car, close door, attach seatbelt to eliminate any distractions including radio. Turn key to the on position and stop FAST 5 times and watch the engine light...dont work? do i again...persistance pays. Wait at least 10 seconds between attempts if you dont get it the first time.
    Apr 2004
    New Hampshire
    I'll go try again right now...I've tried quite a few times in the past but never got it to work. Hopefully persistance will pay
    Kingston, Ontario, Canada
    Dennis, maybe it's the Nikasil! *LOL* Welcome to the club. Like Jeff says, it can be a PITA but persistence pays off!
    "Have it you indeed, warrior young. But purpose and conviction to stomp with you must!" Yoda
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Apr 2004
    New Hampshire
    So you can do it on your 540? I was just in the garage again and I still can't get it to work.
    I wanna make sure I'm doing it right... I turn the key to the position juat before ignition. Then, almost immediatly, (I think I tried waiting a couple seconds too) I hit the accelorator to the floor five times as quickly as I can. On Bruno's site it says 5 times within 5 seconds, should that maybe read 5 times over 5 seconds, i.e., once a second?
    When you first turn the key to the appropriate position there's some blinking and dinging, should I wait till thats all done with or just get right to it?
    Quote Originally Posted by DueyT
    netmgr Guest
    Default what
    blinking and dinging of what?
    not the blinking of a check engine light by any chance?
    Default If your car has been to the dealer and had the eeprom flashed then the
    stomp test no longer works and you need a scan tool or code reader to read the codes.
    Quote Originally Posted by wengenstein
    Apr 2004
    New Hampshire
    no
    Quote Originally Posted by netmgr
    Default turn the key all the way, just before engaging the starter.
    Apr 2004
    New Hampshire
    Thats gotta be it...I've tried everything. I'm going to go get dinner and order a code reader..
    Thanks for the info Bill!
    Dennis
  1. stomp test?
    By schnell944 in forum 5 Series BMW
    Last Post: 11-15-2006, 12:25 AM
  2. Stomp Test
    By SLIPPERY in forum 3 Series BMW
    Last Post: 05-30-2006, 05:44 AM
  3. Stomp test...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 05-13-2006, 02:03 AM
  4. Stomp Test help
    By Springfield1952 in forum 5 Series BMW
    Last Post: 02-21-2006, 07:36 PM
  5. Stomp test..?
    By ilya in forum 5 Series BMW
    Last Post: 03-17-2004, 11:11 PM
