i was lucky on my 535, it has a factory reman in it that's not even dirty yet, if i had to guess it has 50-60k on it (i've put about 26k in two years), if i have it long enough ill get into it, they never put the improved seals in the factory trannys (if you order a rebuild kit it comes with the steel seals) the sweetest zf i've driven is in moms 80k mile 90 325isa, if your easy on the throttle you don't even feel it shift, if you ass down on it, it chirps 2nd and down shifts nicely. as for rebuilds all but the best shops are going to reuse a lot of the hard parts, which is not too bad, but the best shops are going to charge about the same $ as the dealer for a zf reman which id rather have, we got one for a friend of the shop for his e32 735, if i remember right it was about $1200
Originally Posted by
George M
who did the neutral slams. See what you mean. Tranny work is tough...both in pulling the trans, repairing them and then seeing if they stay together after the fact....why Kirt Koeller bought a dyno for his shop so he could test everything he rebuilt...a lot of steps involved...best to check one's work if possible and a dyno helps.
Have you ever had the autobox apart on your 535i?
George
