Here are two options I found searching the archives:
Option 1:
If you go to the drivers door insert the ignition key and turn it as fare as you can to the Left you'll find that the lock has multiple positions.
Holding it in the fare left position and raise the door handle this should open the door even without electricty, "Emergency Operation".
To be on the safe side check this procedure in your owners manual or call the local BMR dealer if the manual's locked in the car.
great thing with the Bmw E34/E32 is that it is almost impossible to open the doors without the key... But when your battery dies this feature might get you stuck outside of your car.
Unlocking procedure: ( Procedure courtesy of "the Master" Bill R. )
1. Insert the master key into the front right door.
2. Pull up the door handle.
3. Turn the key counterclockwise to emergency unlock position 1.
4. Open the door.
5. Close doors and turn the right front door lock to the synchronize position 5.
This is for the driver door. The passenger door is the mirror image of the picture
Option 2:
You can pop the hood by inserting a long flat head screwdriver thru the grill on the RH side of the kidney(you looking at it).difficult for me to describe the exact loaction but if you shine a flashlight in the vicinity you will know the location.
insert the screwdriver fully and turn.
Good luck,
Aaron
Aaron
95 525iT (130k m.)
86 325 (190k m.)
76 2002 (125k m.) sold
