whats wrong with the lad, leaking shocks or valve? or hard ride? hard ride is the accumulators have filled with fluid and need replacing 37 21 1 132 043 is the part# theres 2 of them and they are $215 each at the dealer, with some shopping they can probably be had for around $150-175 each. i show the shocks for a e32 (don't have a listing for the e34) to be $500 at the dealer and my cost is $317 so you can count on around $375-400 with some shopping, you can probably find some shocks and or a valve used if they are the same as a e32 (which id guess is a good chance) for at least half of that or less if they don't know what it's worth. used shocks or valve are ok as long as they are not leaking, accumulators should be purched new as they are the wear part, the shocks are just hydrallic cylinders and don't really matter how old if dry
