Results 1 to 10 of 10
Thread: Tire noise
    Nov 2004
    Glendale, Ca
    Default Tire noise
    I've had my E34 for 2 years and just now I start to notice a noise every time I drive. I had a similar problem with an old celica and I found out that the rear tires were the same as the front ones. What does a E34 is supposed to have? 16's 17's front/rear, the same? please advice.
    Wellington,New Zealand
    15 inch 205/65,s were standard front and back unless you have an m5.
    Nov 2004
    Glendale, Ca
    Thanks!
    Default might want to do an inspection on your
    center bearings and rear end just incase something is starting to get worn before it gets worse.
    New York
    what would be your course of action. I have a feeling I need a wheel bearing (on the right side of the car) because the noise is evident when I turn to the left (thus loading the right) and goes away when I turn to the right. what is the center bearing you speak of? I don't think my problem is the rear end though. how would you attack the problem?
    TIA
    Default is it a running/grinding sort of sound?
    and you suspect the front wheel bearing, maybe have someone ride with you and stick their head out the window to help isolate the sound. Thats what I would do before i went and started replacing parts.
    New York
    yeah, it's a wheel bearing. I'm about ready to order one. thought it was my old $hitty tires. I replaced them and it's still there. what are the center bearings you speak of?
    Default the driveshaft has one right in the center,
    thats called the center bearing.
    Minnesota
    Center bearings are a driveshaft part, not sure the sound would change like you're experiencing: noise there when turning left, not there when turning right.
    New York
    next question:
    how to determine front or rear?
    Quote Originally Posted by JonE
  1. Replies: 5
    Last Post: 08-22-2006, 10:37 AM
  2. Tire pressure
    By mitch2k in forum 5 Series BMW
    Last Post: 07-03-2006, 03:06 PM
  3. Anybody want a tire?
    By Kalevera in forum 5 Series BMW
    Last Post: 04-27-2005, 06:59 PM
  4. tire sizes
    By Hans Stuck in forum 5 Series BMW
    Last Post: 04-23-2004, 01:42 AM
  5. Tire Pressure help
    Last Post: 04-17-2004, 09:19 PM
