Results 1 to 5 of 5
Thread: alarm problems........
    SCHUYLKILL COUNTY, PA.
    Default alarm problems........
    after i first purchased the car i had a problem with the keyless remote not working at certain places. but now it is starting to act up randomly. does anyone know what can cause my key to work one second & not another? i have 2 keys, installed new batterys, & re-encoded them both. both keys act the same. what freq. do the keys operate on? could it be a computer problem?
    i would appreciate any help.
    thanks
    tim s.
    Nov 2004
    Powys, Wales UK
    is the LED lighting each time your press it or occasionally? could be a fracture in the pcb.
    Matt.
    Haynes - "Fitting is Reversal of Removal"
    Apr 2004
    Reston Va
    i have the same problem of intermittent Central Locking System functioning. I have never been able to tye it down to a particular set of circumstances that causes it.
    There have been several posts on this board and on others stating that it is a fusible link problem and if you replace the fusible link things should function properly. I havent done this yet.
    If you do try it please be sure to report back on your results. - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Default I've had the same problem......
    usually when it happens there's a 'cell tower' in sight. I've learned that if it doesn't lock on the first try don't push my luck. Sometimes I get it to unlock by inserting the key in the lock and then pressing the button.
    Default the light blinks when i press the button.....
    the local dealer told me that i can open the the door with the key, the alarm will go off, after getting in turn the key to the running position, then off, then try starting the car, he said this should disable the alarm. i tried this & only got it to work the one time. since then i was only able to disable the alarm with the remote. i am interested in the fusable link though.
    thanks
    tim s.
  1. Alarm Problems
    By Yoss520I-M50 in forum 5 Series BMW
    Last Post: 05-29-2008, 12:58 PM
  2. alarm/central locking problems
    By spiritusuk in forum 5 Series BMW
    Last Post: 03-17-2008, 05:54 PM
  3. Alarm problems, Merry Christmas to me !
    By jrgibb in forum 5 Series BMW
    Last Post: 12-19-2006, 10:36 AM
  4. Replies: 16
    Last Post: 12-13-2006, 08:22 PM
  5. Alarm/Keyless entry problems!
    By rockyfeller in forum 5 Series BMW
    Last Post: 01-09-2005, 01:53 AM
