Results 1 to 5 of 5
Thread: No pressure in the cooling system. Is that right?
    Aug 2004
    Argentina
    Default No pressure in the cooling system. Is that right?
    question: after having a lot of trouble with the cooling system, (too much pressure because the cylinder head was cracked, so all the hoses started leaking) i fixed the head, changed water pump, hoses, thermostat, and now its running ok, temp is always in the middle and a bit less. But the system has noo pressure at all. Is that a bad sign? My car is really running fine, so i guess there is no problem.
    What do you think about this?
    netmgr Guest
    no pressure when...at start up...running for 20 mins??
    Aug 2004
    Argentina
    it never gets pressure, not even after driving 30 minutes in highway nor in city
    baton rouge, loserana
    if it's cool outside and the system is in good shape it just may not be building pressure, which is not a bad thing in and of itself, or you could have a bad cap and it's bleeding it out
    could be the cap on the expansion tank.
  1. no cooling pressure
    By jstew4u in forum 5 Series BMW
    Last Post: 05-01-2008, 07:23 PM
  2. Getting the air out of the cooling system
    Last Post: 12-17-2005, 12:23 AM
  3. problem with hoses pressure of the cooling system
    By PABLO in forum 5 Series BMW
    Last Post: 08-14-2004, 11:24 AM
  4. Pressure Test - Cooling System - ? PSI
    By Jimmy535i in forum 7 Series BMW
    Last Post: 07-12-2004, 08:36 AM
  5. Replies: 12
    Last Post: 05-11-2004, 12:50 AM
