Maybe your engine is coked up in the first place whereas the synthetic knocked them loose and cleaned your engine...
I have used Mobil 1 0w40 for the past 16,000 or so miles. I have changed oil and filter (Mann) every 4,000 to 4,500 miles. I have never had the oil stay amber colored for long. It seems to get dark quickly. For example, my current oil has only 2,500 miles and feels a bit gritty when run between my fingers. Car runs fine. Is anything-wrong going on here?
I may be just a bit paranoid. TIA
I have gone through several oil/filter changes. Would have thoughtti would be cleaned out by now?? Thanks
Originally Posted by Tiger
valves i notice a little less buildup in the head in the valve cover and inside surfaces of the head, it looks like synthetic oil has a nice slow detergent process cleaning up all the old buildup, varnish and sludge slowly....I wouldn't be too concerned about yours.
Originally Posted by Russell
That is why it starts creating leaks sometimes.... cleaning up the seals and gaskets.Originally Posted by Bill R.
I am always worried about switching to synthetic on old engines...
Originally Posted by Bruno
If you are really concerned, do a oil analysis service.
if you get leaks after changing to a good oil you have issues about your gaskets not an oil.
no leaks at present
It was in the early days, but for some time synthetics have an additive that helps expand seals to prevent this. If you do get a leak after changing to synthetic, then I think you probably had a lot of gunk that was preventing the seal from even getting lubricated by any oil at all. Not a good situation and one that needed to be corrected.
