Bleeding the M30, did I loose my touch?
I must have bleed something like 10 E34s.
I never had a problem.
Removed the coolant from the radiator and the engine block.
Put all the plugs back
REmove the bleed screw.
Poor the coolant slowly until it runs out of the bleed screw hole.
Put the bleed screw back and add more coolant.
Put the cap back.
Start the car, car goes hot. Shut it down.
Open bleed screw.... no air, no bubbles. Just coolant.
Did that many times. Still no heat inside and car just overheats....
Did I miss something?
Top rad hose is not very hot. Could be thermostat I guess...
