I recently replaced the intake manifold gaskets on my 535i M30. One of the gaskets had failed so there was an air leak and I was getting the 1222 oxygen sensor code. A good independent shop gave me a price estimate of $500-700 for the job. The task of removing the intake manifold was not as hard as I had been led to believe -- people had mentioned how difficult it is to reach some of the 12 nuts holding it on, but with the right tool it was easy. Taking my time, disassembly and reassembly of everything took about 4 hours each for me, a moderately experienced home mechanic.
The key trick was to use a universal-joint 12mm socket on the hard-to-reach nuts that people mention. The problem with these nuts is that their axial centerline points slightly upwards towards the underside of the manifold, so socket and extensions have to angle away before they hit the underside. The universal joint permits that angling away. In a couple of cases (nuts 5, 6), it was hard to get the socket off after tightening the nut, because the clearance was so small!
To reach these nuts, put the universal socket on the end of several straight extensions, and guide it high along the underside of the manifold (above the coolant hoses), straight towards the relevant stud. Slide the other hand underneath the manifold and put a thumb and finger on either side of stud to guide the socket on, slipping it on so it feels like it points up slightly. Unless you have even longer arms than me (I'm 6'1"), you can indeed reach each of the studs with the guide hand. All the nuts could be loosened/tightened with the extension bars coming pretty much straight out. No need to go underneath the car. Don't lose the wave washers under the nuts, a magnet can help to bring them out.
I did not use the S and half-moon wrenches I had ordered, the universal socket did all lower nuts, with the added advantage that a torque wrench could be used to tighten the nuts. Reaching some of the top row of nuts was helped by disconnecting the wiring tray from injectors. The hard-to-find part number if any of the little black clips (that go over the injector connectors, and along the bottom of the wiring tray) break is 12 51 1 711 433.
You do not need to take off the two coolant hoses running under the manifold (just remove them carefully from the plastic clips), nor the oil filter housing or fuel rail. For access, I did remove the manifold support bracket, and disconnected the gasoline vapor valve/hoses. To take the manifold all the way off, which possibly is not necessary, you also have to disconnect the fuel lines somewhere (I did at manifold support bracket), the brake booster vacuum tube, throttle and cruise control cables and cable bracket, injector connectors, throttle position sensor connector, and charcoal canister gas line.
Hope that's useful,
Marcus
'92 535iM Lazurblau
