Results 1 to 3 of 3
Thread: Radio Station Illumination
    Default Radio Station Illumination
    Today the windowon the radio that displays the station became very dim. I suspect that a llight bulb or LED has burned out
    Can anyone tell me how to replace the necessary bulb or LED
    Don
    Communist-wealth of Massachusetts
    Quote Originally Posted by Don
    Don
    Don,
    Find out which radio you have (Alpine or Pioneer) and contact the manufacturer. Give them the model number of the radio. They will tell you that you need 3 (maybe 4) bulbs for the screen and the buttons. Order a couple extra....(don't ask, got to do this twice because they told me the wrong number of bulbs).
    Pull the head unit and move to a work bench. I don't remember off hand how to open the radio but it was very obvious looking at the back and bottom. I believe there are a couple screws on the back but it has been a few years since I did this. Once the cover is off you can see the bulbs on the front. You will need to de-solder the current ones and re-solder the new ones in. You only need to replace the dead one but I would recommend doing them all while you are in there. Parts should be <$5 shipped and it can be done in 25 minutes if you are descent with a soldering iron. Installation is reverse of removal.
    Good Luck,
    Rory
    <Insert list of modifcations or clever saying here>
    Default Here it is courtesy of Jeff N.
    Radio light fix
    Don
  1. Need help w/OBC LCD Illumination
    By billy in slo in forum 5 Series BMW
    Last Post: 11-01-2010, 11:57 AM
  2. C33 Illumination Problems
    Last Post: 11-11-2009, 07:13 PM
  3. Replies: 1
    Last Post: 11-14-2008, 01:16 AM
  4. NJ Inspection Station that will pass Tint
    By saj3n in forum 5 Series BMW
    Last Post: 11-02-2006, 07:30 PM
  5. Replies: 9
    Last Post: 09-20-2006, 04:49 AM
