Results 1 to 10 of 14
Thread: Having auto tranny problems...control module related...
    Default Having auto tranny problems...control module related...
    Hey guys...let me start of by saying merry christmas eve, hope everyone is enjoying thereselves. Now, to the problem...my mom goes to drive the 540ia this morning and later into her commute, while she's slowing down for a stoplight the OBC reads Transmission Program... See Owner's Manual.
    Just took it out for a slow spin around the block and didn't see anything come up...just one time where there was, what seemed to be a abrubt downgear from like 3rd to 2nd as I'm going into an entrance.
    If anyone has any experience with the slushboxes in these cars...or has replaced the control module...that'd be awesome to hear some feedback.
    What a time for something like this to go wrong...
    -Trevor Ely
    '88 535is
    '95 M Sport 540i (1 of 200)
    '91 M5
    If this is the first time its ever happened there's still a chance you could get out of this cheap. You need to take it to a shop immediately and have the codes read. You can drive it very carefully in transprog mode (3rd gear), but no more than a few miles to get to a shop.
    Possible causes:
    Valve body defect
    Solenoid
    Speed Sensor
    ECU fault
    temp sensor
    or worse:
    internal clutch packs
    torque converter
    One final possibility is that your shifter seals are leaking and your fluid's gotten way low. This is a diy. You should see a very oily tranny pan, and burned up material where the pipes come together behind it. If you have that just top it off with esso or Shell la2634 ONLY!!! (very expensive- call jaggi import-do a search)
    keep us posted on any quotes you get and we'll tell you whether they're ballpark.
    Quote Originally Posted by tim
    Possible causes:
    Valve body defect
    Solenoid
    Speed Sensor
    ECU fault
    temp sensor
    or worse:
    torque converter
    Alright, well it had a tranny rebuild at 108 and it's got 130k on it now if that changes anything....and it is the first time it's happened while we've owned it, so like almost a month.
    So, just leave it in 3rd the entire time? Or will it automatically throw itself into 3rd.
    Thanks so much for the help.
    -Trevor Ely
    '88 535is
    '91 M5
    If it comes on right when you start it, you are in limp mode- which is third gear- the easiest gear on the tranny as far as line pressure.
    Yeah, it's not coming on now. So, I guess for the time being it's not going to show itself.
    As odd as it sounds, could this have anything to do with cold/moisture...the car was left outside last night...and it was quite cold and the car's entire life has been inside a garage. Is there any chance this could be something triggered by the climate change?
    -Trevor Ely
    '88 535is
    '91 M5
    Quote Originally Posted by MTechnik540i
    That's why I'm thinking low fluid. The stuff is very temperature sensitive and the case volume can expand or contract by over a liter depending on temperature.
    Check that case and pan for me. Do you have a leak?
    BTW, even if it doesn't come back on, the error code that generated it will be stored. If the fluid is low, the code will most likely be temperature.
    Yeah, i'm going to check the pan again....if it is the fluid, how easy is it to refill?
    Thanks so much Tim.
    -Trevor Ely
    '88 535is
    '91 M5
    Very easy. You'll need some stuff like a 17mm hex key, a cheater bar, the right fluid, a section of tubing connected to a pump, jackstands or a lift.
    Down here in Texas its very hard for the tech's to get the fluid right on the 540 during the summers, where at its coolest, it's at the middle range of temp spec for filling. It's easy in winter, where we can let the cars warm up to the lower end of the temp range, and not have it go through the top end in two seconds.
    Before drawing any conclusions, we really need to see that code, or some oil on the pan.
    Yeah, well...we won't drive it 'til next week...and i'll have my friend hook it up to the ECU.
    -Trevor Ely
    '88 535is
    '91 M5
    Well, Tim...if you're still following this thread...it seems as it is what you were talking about...there was a little seepage on the base of the tranny...seemed to be leaking towards the back of it. So, thinking it could be a seal or something. Either way, i'm watching it for now on...and a tremendous thanks for the heads up.
    -Trevor Ely
    '88 535is
    '91 M5
  1. Cruise Control Wiring E34 / Auto Tranny major leak
    By DaveVoorhis in forum 5 Series BMW
    Last Post: 01-30-2008, 07:52 PM
  2. Replies: 11
    Last Post: 04-09-2007, 06:36 AM
  3. Idle problems -- AFM related
    By SRR2 in forum 5 Series BMW
    Last Post: 12-15-2005, 06:22 PM
  4. Electrical Problems - LKM Related Only?? (1992 e34)
    By afxjzs in forum 5 Series BMW
    Last Post: 09-22-2005, 01:55 AM
  5. Replies: 8
    Last Post: 09-18-2005, 01:40 PM
