Results 1 to 4 of 4
Thread: Help!!! Rear door locks
    Scotland
    Default Help!!! Rear door locks
    Yesterday I put the beemer in for it's MOT and it failed on a few things. It's an '89 535i SE Manual...and these are my main worries.....
    First up only one sidelight comes on when there's no key in the ignition and the lights are on (but not on dipped).
    Secondly the rear left door lock isn't operating....has only done this in the last few days, just before my MOT!! I can't pull the lock knob up and I think i've done everything right to reset the locking system.
    If you guys have any suggestions I would in your debt. I only have a week to fix it, then I have to fork out more money I can't afford for a new MOT.
    Default Are you in a cold climate? (m)
    it is possible that they are frozen if you are in a cold area and it has snowed or you washed the car recently. if that is the case try to find a warm place and let it sit for a day.
    Scotland
    Default I've found water around the....
    wiring for the locks (next to the left boot/trunk hinge) it was coming through the mount for the aerial. Some of the wires have cracked insulation. I'm about to check the fuses to see if it's shorted..and clean up the wires cause the WD40 I sprayed on to disperse any water has become sticky and messy. Maybe I'll try soldering the wires...is that a good idea?!?!
    Bob
    Wellington,New Zealand
    Default the boot hinge area is known
    to cause problems.The wires to the boot lock can short so causing locking problems elasewhere.I dont understand your light problem.Are you saying one front parking light doesnt come on?
    Gone but not forgotten
  1. Replies: 7
    Last Post: 08-03-2009, 07:28 PM
  2. Replies: 8
    Last Post: 06-18-2006, 05:26 PM
  3. Door locks pop up!
    By laguner in forum 5 Series BMW
    Last Post: 11-06-2005, 01:17 PM
  4. Door locks
    By montsta56 nz in forum 5 Series BMW
    Last Post: 09-13-2005, 01:20 AM
  5. Door locks
    By Frustrated in forum 5 Series BMW
    Last Post: 08-26-2005, 11:42 PM
