Hi all!
I'm searching the posts since a while to get info on oil leak from oil filter housing. After reading everything I could find on this topic here is my first post (or thread reply).
I have a 1993 (build 05) 525i auto M50TU with 1.5 year old valve cover gasket, oil pan gasket, rear plate seal. I still have a moderate oil leak (1 quart every 500-1000 miles) from oil filter housing.
My mechanic told me it's gonna be 500$ for the parts and 3 hours of work. He said there are no gaskets to change, I got to have a new housing.
Any clue if I could get that done for cheaper than 900$? Is it true that it is not serviceable on my car? (remove, clean, change gaskets, o-rings, etc?)
If it has to be replaced as a whole, is there other stuff I should ask to have a look or replace once in there?
I did some basic work myself on the car before (like replacing heater valve, aux. water pump, ac microfilter, headlight assembly, Gearshift/neutral safety switch, Front left door bowden cable for opening door and window motor) but I'm not sure if I could replace the oil filter housing myself... (I also need to remove steering pump?)
There is no info in my Bentley how to do this oil filter housing replacement, someone has a procedure? (with pics it would be better of course but anyhow...)
Thanks for any advice!
Alex
Also, huge thanks to people posting solutions, not only questions! I've been using this site since 2 years I got my first Beemer and it helped a lot!
1993 (build 93/05) 525i automatic M50TU (vanos) 263K miles (ca. 423000 km) in Montreal, Canada (bought the car 9 years ago in San Diego, CA)
