Thread: PEAKE R5/FCX-II Code "0A" says...
    Nov 2004
    Washington
    Default PEAKE R5/FCX-II Code "0A" says...
    Emission (lambda) control. The "0A" code is the fault code that comes up on my 89 535i 5-speed. The car runs and drives fine. Been driving it for a week now since I put a used ECU from a 89 737. It actually seems to run and drive better than the remanufactured one that was in when I bought the car. That ECU fault list came up "--" no faults. I don't have the remanufactured ECU anymore...ruined by me. Anyways, I'm new to BMW's and could use some help...anyone know?
    1989 BMW 535i 5-speed manual
    Australia
    You get that when the O2 sensor is telling the ECU that it is running too lean or too rich for too long.
    I had the same problem on my car and the fault was with the O2 sensor. It was telling the ECU that the car was running too lean, so the ECU kept making it more and more rich. It fouled the plugs and ran like crap.
    But since your car is running OK, so you might find the problem is elsewhere. Possibly a vacuum leak?
    Default Make a reset and test again
    I had the same some weeks ago, and funny, both on my V12 engine should be defect.
    Finally I found out that it was an old stored fault.
    Made a reset/deleted the faults, drove the car around the block, tested again and no fault anymore.
    Note that when you make a reset, that before you test the car again, drive for s short while or let the car come to normal operation temperature.
    The oxy sensors measured values are overridden during the first 90 seconds or so by the ECU which works with a nominal value till the cats are heated up.
    Nov 2004
    Washington
    Default I will give the reset a try...
    Thanks for the help. I'll let you know what happens. It'll have to wait till I get home later.
    Vancouver, Canada
    nice ride man.. looks awesome
    -inc
    '91 e31 850
    '90 e34 535
    '02 CBR F4i stunt/track bike
    '07 gsxr 750 stunt bike
    Diagnostic procedures & Frequently Asked Questions https://secure.lambdapower.co.uk/dia...c_index.asp#q3
  1. Peake Tool - Will it tell more than just "1221" ??
    By Super90 in forum 5 Series BMW
    Last Post: 04-11-2007, 01:37 PM
  2. Remote Start Alarm System that bypasses "CODE"
    By saj3n in forum 5 Series BMW
    Last Post: 10-26-2006, 04:49 PM
  3. Trans Code "100"...code of death? '94 525i
    By rizal in forum 5 Series BMW
    Last Post: 10-04-2006, 06:56 PM
  4. 540 barely runs. Code 1222, "Lambda Control" ? Help!
    By STingray1100 in forum 5 Series BMW
    Last Post: 09-27-2006, 08:49 AM
