Results 1 to 4 of 4
Thread: E34 Error code 54 ???????
    Jan 2005
    Default E34 Error code 54 ???????
    Further to my note about my 520i '95 Touring a few days ago running flat as a pancake, no power etc etc, the local (non-BM) garage say its coming back with an error code of 54 when they plug their diags in.
    Anyone have an idea what fault this code relates to please?
    They looked in their book and it listed fault descriptions for 1-53, and 55-200+ but a blank for 54!
    TIA
    Rick
    (wishes he'd hung on to his 750i and Merc 300TE instead)
    Default You need to specify which version of the dme you have
    Its most likely version 3.3.1 and if it is then the error code 54 is for
    Dme control -unit power supply via main relay...
    Whether that helps you any i don't know...
    Jan 2005
    hi Bill
    thanks - not sure on version, only recently bought this thing unfort.
    rgds
    Rick
    Jan 2005
    3 possible problems for code 54
    1/. Engine control module (ECM).
    2/.Transmision control module (TCM).
    Both are communication faults (wiring short to earth, TCM trouble codes stored.
    3/. Battery voltage-too low/high
    fault could be wiring/alternator/battery
    1989 e34 520i se, red, mint condition (original)
    pro mechanic "all cars"
  1. Transmission error code. (e34 535ia)
    By Espen in forum 5 Series BMW
    Last Post: 01-09-2008, 06:15 AM
  2. Error code 1222
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-22-2006, 05:28 PM
  3. Lambda error code 1213 - Diagnosis Help Please
    By KBarcellos in forum 5 Series BMW
    Last Post: 04-19-2006, 09:44 AM
  4. Check Control error and 1213 code
    By Zander in forum 5 Series BMW
    Last Post: 11-04-2004, 06:19 PM
  5. Auto Tranny Error Code
    By DonC in forum 5 Series BMW
    Last Post: 08-25-2004, 12:20 PM
