Results 1 to 10 of 11
Thread: OBD Question
    Default OBD Question
    Hey guys! I have a 1995 540i 6 speed. The "Check Engine" light came on, so I went thru the procedure to read the codes outlined in the Bentley Manual. (Page 100-8, On-Board Diagnostics) Now I want to erase the fault code memory, but the damn thing just keeps flashing the same fault code over and over again! It doesn't stop like it says in the manual. It should stop flashing fault codes, then remain off, then you should be able to reset it. Anybody have any ideas??? Thanks!!!
    MLR
    Wellington,New Zealand
    Default You have to fix the problem first
    otherwise the computer just reports the problem again.You could try disconnecting the battery but dont forget your radio code (if you have one) to see if the fault clears
    Gone but not forgotten
    Thanks for that Paul! Bentley does say that it should read off the codes, display a .5 second flash, then the light will stay off. Then if you want to read the codes again, you repeat the procedure. This thing has been flashing the same code for an hour! The way I read Bently, it should stop flashing codes when it has flashed them all (If there is more than one)
    Default To clear the codes, you wait until it has flashed the code then there's a long pause
    before it starts to flash the codes again. Right when you get the long pause after flashing the codes you hold the gas pedal to the floor for 10 seconds to clear the codes.
    Quote Originally Posted by mlrwy
    Hi Bill! Just ran out to the garage and tried your suggestion, still won't stop flashing the same code! What it does is flash the code, go off for 5 seconds, comes on for 5 seconds, off for 2.5 seconds, then repeats the code again. Does this over and over! I tried holding the gas pedal down for 10 seconds AFTER the code (during the 5 sec. pause) and also holding it down for 10 sec. AFTER the 5 sec. on & before the code flashes. No luck! It just keeps doing the same thing!
    Default Turn it off and try it again, sometimes it takes a couple of trys to get it right.
    1
    O.K. Tried it quite a few times again! (MAN it's cold out there!!!) Waited for the code to flash and as soon as it paused, held the pedal down. It just kept doing it's thing! Flashing the code! I'm wondering, if a fault has exsisted for a while, would it record it each time you start the car, or would it just record it as one fault?
    Default If its a hard fault it will show up almost immediately , if its an
    intermittent fault sometimes you can clear it and then it won't come back for a day or two of driving.. Depends on what the fault code is for.
    What code are you getting?
    Hey Bill, got sidetracked! It's the 1213 code (O2 sensor #2 lean/rich control stop) Gonna give up for today... thanks for the help...I'll try again tomorrow.
    Default That code should clear and then not come back for about 5 minutes if its a
    hard fault..
  1. Replies: 1
    Last Post: 11-06-2009, 07:35 PM
  2. Fuel filter question and bumper question
    By 1995 525i in forum 5 Series BMW
    Last Post: 08-26-2004, 08:22 AM
