If it stays on then you either have, or had, a fault somewhere. Did you recently clean the interior, or have a spill?
If you haven't got a code reader, you should take it to a dealer or your indy and get the code(s) read. Depending on the fault the airbag should still function though. I'm not familiar with many of the SRS faults but if the problem is something like a set belt sensor or the passenger seat pressure sensor the airbags should function normally.
Dennis
Originally Posted by wmann
