Results 1 to 9 of 9
Thread: brake light problem 88 528e
    Jan 2005
    southern calif
    Default brake light problem 88 528e
    i'm new to this site and it is awesome. I can find all my answers to everything I have needed so far!
    My problem my daughter's 88 528e has had a problem with her brake light going out. We have switched the bulb sockets, bent them also to get a good connection...and nothing works...When i switch the bulb into another socket...it works fine but any one i put in the (right) brake light won't work. Does anyone have any suggestions for a novice?? Thanks for your help...
    Nov 2004
    Middle England
    I too am puzzled by a similar problem ... except its the right hand reversing light bulb only ... otherwise exacly same comment ... anyone out there know a solution ?
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Default From below posted circuit, ...
    you may see that left and right bulbs are feed trough "Rear lights check relay", but in different pads, one coil for each bulb. Guess you should have a bad relay contact/soldering point/coil and you may fix/diagnose it following procedures suggested by Shogun. Also posted is a picture that should help you find and remove the relay.
    Javier
    Edit: Pictures in these links, as they are missing somwere.
    http://www.bimmer.info/forum/attachm...ntid=769&stc=1
    http://www.bimmer.info/forum/attachm...ntid=770&stc=1
    Forgot something: have you checked if there is power arriving there? Simple multimeter will do.
    Apparently there are some wire looms breaking where they go from the trunk into the passenger room.
    Jan 2005
    southern calif
    Thank you very much...I will give this a try and let you know how it turns out...I appreciate your help..
    Jan 2005
    southern calif
    Quote Originally Posted by Javier
    Javier
    Thank you for your help on this. I will try this procedure also and the diagram will definately help out.
    Nov 2004
    Middle England
    many thanks ! I will try this out for sure
    '86 F288 69k miles
    www.pyghtle.com
    Default Back-Up lights are not monitored ..
    by LKM (E34) nor Check relays (E28). If one bulb is not turning on, and it is not the bulb, check the wiring and connections, not only from the battery but also to ground. Being the other side OK, all checks should be confined to the trunk.
    Javier
  1. Replies: 14
    Last Post: 05-12-2009, 08:44 PM
  2. Brake Light, Tail Light, Licence Plate warnings
    Last Post: 09-24-2007, 05:01 PM
  3. E28 528e Starting problem
    By ArtemLepilov in forum 5 Series BMW
    Last Post: 10-21-2006, 05:29 PM
  4. Brake light, sunroof, doorlock and window problem
    By rosiebimmer in forum 5 Series BMW
    Last Post: 05-20-2006, 06:54 AM
  5. Brake light problem
    By Craig in Davis in forum Electronics & Lights plus A/C
    Last Post: 09-06-2005, 02:41 AM
