you can just about squeeze the instrument pod out without removing the steering wheel it takes some effort,but make sure you move the steering wheel back if you have ajustment on it ,the nut is a 22mm nut with a nylon locking thread on the end so if you decide to remove the wheel you should buy a new one,from the dealer ,hope this helps.Originally Posted by ElNormo
