Results 1 to 10 of 10
Thread: Im in a little bit of a bind. Seems there is no coolant
    NYC
    Default Im in a little bit of a bind. Seems there is no coolant
    in my car at the moment, it appears to have leaked out though i havent pinpointed from where yet. Is it ok to use another brand or do I have to use the BMW coolant.
    Default There are ok alternatives to the BMW stuff, but do not
    use the Dexcool coolant ever in your BMW. I think that stuff is always orange in color. You should try to find coolant that is approved for alumimum radiators, which means phosphate free. I wouldn't put the generic green stuff in my BMW's, but you would probably be fine in the short term using it.
    Dick Schneiders
    Quote Originally Posted by Jason
    Midlothian, Texas
    Default You can use plain water temporarily...
    Just don't let it sit too long in sub-freezing temps.
    Mark Hall
    '95 525iA EAT chipped (just one now )
    '98 528iA
    Connecticut
    The Zerex G-05 is pretty much identical to the BMW blue only a different color & price. Autozone carrys it around here.
    Default Actually Dick prestones new extended life thats compatible with every
    type of antifreeze they say, is now green again instead of orange like the earler prestone extended life was... Real dexcool is still orange though...but the prestone was sold as dexcool compatible. I use the blue stuff in my own cars just because i prefer to stick with what the manufacturer specifies but for the short term i wouldn't hesitate to use prestones new one. I use that in most customers cars who don't have a preference.
    Quote Originally Posted by Dick Schneiders
    Dick Schneiders
    NYC
    Default I wound up going w/ the BMW coolant because the dealer is
    actually a little closer than the nearest autozone. I checked out some of the old posts to see what they said. But i was pressed for time and so I headed to the dealer cause it was the safest bet. It seems to be leaking from somewhere under the reservoir. I cant pinpoint it. My car isnt doing well right now, its been stalling and it doesnt start right up afterwards and the idle has been inconsistent either settling as low as 500 or as high as 1200. Any one have a simple answer for me? my fingers are crossed.
    thanks
    J
    Jan 2005
    Chicopee, MA
    Check the hose that goes over the reservoir, if I remember correctly, anyways check the ring around it. If necessary tighten it or put another one next to it. Had same problem last month, all coolant leaked out overnight.
    Jan 2005
    Reno, NV
    check all of your hose clamps, but make sure thta they you do not over tighten. might try to wiggle them first to see if the plastic collars are broken. I would say, put water in and turn on the car, once it gets to pressure your will know right where it is leaking.
    Jason - having just rebuilt my '90 535i's cooling system and agonizing over the associated problems of doing so: 1) is ALL of the coolant gone, or just in the expansion tank/upper part of the system? In my case, I had a bad expansion tank hose (runs from exp tank to heater core and thermostat housing via the underside of the intake) that was leaking all over the place as well as a VERY non-visible leak courtesy of my aux water pump. The latter was only visible with a mirror or taking a hard look by the brake vacuum boost unit (it's hard to see down there). 2) what's your heater core doing? radiator?
    Hopefully it's something simple like a loose radiator or engine block drain plug (ha ha). But I suspect, especially if you're in part of the country that gets cold at this time of year, one of the famous plastic parts has developed a weeping crack.
    best, whit
    Aug 2004
    i just put water in
  1. oil in coolant
    By dwaynos in forum 5 Series BMW
    Last Post: 06-12-2008, 06:12 PM
  2. Check coolant message, how do you "top off" coolant
    By gmannino in forum 5 Series BMW
    Last Post: 01-06-2007, 01:13 AM
  3. Where is the coolant going?
    By Jay 535i in forum 5 Series BMW
    Last Post: 02-19-2006, 11:21 AM
  4. BMW coolant
    By Drooby in forum 5 Series BMW
    Last Post: 03-28-2004, 01:57 PM
  5. Replies: 9
    Last Post: 02-18-2004, 11:05 AM
