Results 1 to 4 of 4
Thread: New Problem: Car won't stay on unless I give it gas
    NYC
    Default New Problem: Car won't stay on unless I give it gas
    The car stalls as soon as the revs drop below 1000 and then starting it is a b!tch, i have to give it a little gas to get it turn over. Battery power is fine, head lights are bright and everything works. It seems to run ok when its running, but it just wont stay running, is there something that i can do to temporarily fix this until i take it to the mechanic tomorrow? any help is appreciated. THanks
    J
    NYC
    Default There don't seem to be any loose hoses or anything either
    from the airbox to the intake manifold everything seems to be snug. and the dipstick is in securely as well. when i let the car sit of a little bit it, it starts up again and idles...
    Jan 2005
    Reno, NV
    Get a new fuel filter and run some injector cleaner through. Good luck.
    Default Jason, only thing I can think of ...
    is ICV (Idle control valve). May be a quick check on connections would reveal some bug. Also check TPS (Throttle position sensor) connector, TPS may not be reporting idle position properly.
    Javier
  1. why won't my sun visor stay up all the way?
    By timandbim in forum 5 Series BMW
    Last Post: 01-12-2008, 03:06 AM
  2. A/C Vents Won't Stay Put!
    By we_call_him_doher in forum 5 Series BMW
    Last Post: 06-08-2006, 07:06 AM
  3. door won't stay open...anyone had this problem???
    By Robert K in forum 5 Series BMW
    Last Post: 10-29-2005, 05:53 PM
